16-10-2024 01:07 PM
Hi, can anyone help with a sound issue. Sound is fine until after an advert while streaming on Discoveryplus. Sound then goes off. I can switch to other channels and sound is fine. Then switch back to Discoveryplus and sound is fine until after the next advert. TIA.
05-11-2024 05:27 PM
Hi I am still having the same issue, the TV is a Samsung QE49Q60RATXXU.
Following your advise I checked the HDMI port the EE box is plugged into and it was plugged into HDMI 4 (ARC)
So I moved it to HDMI 2, tried it and it survived the first set of 3 advert , with the sound coming back on after the adds, but then after the second set of 3 adverts, when the program came back on the sound was gone, and the same no sound on every advert break after that, this is the same pattern at it has always done.
So replaced my original HDMI cable with the one EE provided in the box and exactly the same occurred, okay after the first set of adverts but then no sound after the next set of adverts.
As mentioned before my old BT TV box did not have this issue, my contract is with BT so I will ask them to take the EE box back and send me the original BT box.
05-11-2024 07:29 PM
12-11-2024 09:25 PM
Hi. Sorry to hijack the conversation but mine is doing the exact same thing.
Sound disappears after the 2nd ad usually. I have to restart the programme to get it working again.
It happens with Discovery+ but also NowTV occasionally. It can be intermittent but happens most of the time.
Did anything get resolved?
Thanks.
12-11-2024 09:59 PM
12-11-2024 10:21 PM
nope mine still doing it
13-11-2024 07:09 AM
14-11-2024 11:00 PM
I have had the same problem with DiscoveryPlus sound since replacing my old BT TV box with a new EE TV box a few weeks ago. On the same TV as the EE Box I have an Amazon Fire TV stick. I have streamed the same DiscoveryPlus episodes of programs where the EE Box had the sound issue using the Fire TV stick without any issues with the sound disappearing after adverts. This tells me the problem is with the EE TV Box NOT my TV. Like other users have said I didn't have this problem with my old BT TV box plugged into the same HDMI port on the TV.
15-11-2024 10:21 AM
Hi there @UKCooperman
Thanks for posting on the community.
Have you reported the intermittent sound on discovery+ to our technical support team?
The team will run some troubleshooting and let you know what is needed to get this sorted 🙂
15-11-2024 07:16 PM
Hi Leanne,
No I haven't reported it yet as I was waiting until I had proved conclusively that it was the EE Box by doing my test with the Fire TV stick. I will probably try the EE Box again tonight and if no improvement get in touch with support.
Do you know the best phone number or link to use to get in touch with them please?
Cooperman
16-11-2024 10:52 AM
@UKCooperman If you have an EE Mobile the contact number is 150, for any other phone call 0330 123 1105 to speak to our TV technical team.
Alex
