on 31-10-2025 11:12 AM
Is there a way I can turn off "parental control pin needed" from appearing each time please?
Solved! Go to Solution.
on 31-10-2025 12:10 PM
You can change the parental control settings on the TV Box from the settings menu, however you will be required to enter the PIN for some content - specifically channels that are broadcasting content before 9pm with a 15 or 18 certificate. This is known as Mandatory Daytime Protection, and is legal requirement from Ofcom that cannot be disabled:
https://www.ofcom.org.uk/tv-radio-and-on-demand/broadcast-standards/mandatory-daytime-protection
