EE apple TV box remote issues
Weerab2024
Problem solver
Problem solver
I have had my EE apple TV for a year now and the last couple of days the remote is running out of battery, but the batteries are not dead because if I change the batteries to another remote, they still work.
I have tried a couple of fixes suggested online to reset the remote but these do not work.
When I put in different batteries that work when I switch to another remote they last a day and then I have the same experience.
Is the EE supplied remote now becoming faulty?
EE Pro TV box, Full Fibre 900
For EE contact details see
https://ee.co.uk/help/contact-ee
23 REPLIES 23
@DarrenDev apologies for the delay in my response.
Yes I received the remote and can return the old one.
Many thanks for your help.
@DarrenDev I just turned my EE apple TV box on after a day or so and the new remote control also stopped with the supplied batteries (only a week old).
I put in some old batteries and it's working now.
Do you think the issue could be with the box?
I have the same problem
I’m having the same problem
Chris_S
Hi @DSkeelo
If your remote control is showing as having a low battery, could you try adding some new batteries please?
Chris S
I have done that repeatedly, almost daily for the last 2 weeks
Best wishes
Deon
[Mod edit: Removed personal details. Kindly refrain from sharing private details in public forums.]
DarrenDev
EE Product Expert
@DSkeelo can you please check the Apple TV settings screen:
On your Apple TV, if you go to Settings then Remotes and Devices does it say that the battery is below 20% there?
Check this straight after inserting new batteries to confirm it shows 100%, and then verify when you next see the low battery warning.
I changed the batteries. It was 100%. Approx 6 hrs later, without using the telly, it was down to 60%.
Kind Regards
Deon
DarrenDev
EE Product Expert
Assuming there was nothing sat on the remote pressing the buttons, I recommend you press all the buttons on the remote once, to make sure they're not stuck.  If the battery still declines fast, give the helpdesk a call to get a replacement.
None of them are stuck. Now at 20%
Kind Regards
Deon
