on 01-05-2025 10:12 PM
Simple yes or no question. Is anyone using 2 recordable boxes with their EE TV broadband? If yes, how have you set it up and type of boxes used. ie extra multi room? Pro box and /or BT youview box. Thanks
on 02-05-2025 07:09 AM
Officially you can only get 1 recording box, if you have an old BT recordable box they would likely want that back.
Also if you don't have a subscription for the extra you would have difficulty using it.
on 02-05-2025 08:13 AM
@Bunsen If you acquire an additional box from elsewhere yes you can use it but I’m sure you’ll need a mini box with a subscription and are replacing that box with the pro box.
