EE TV mini box stuck at start up process.
Kenno72
Lost channels so did a factory reset, now won't go past the Startup Screen, did a full reset but on the maintenance screen you can't move up or down to select factory reset, maybe bricked?
DarrenDev
EE Product Expert
Now that you've factory reset, your remote is no longer paired. You need to hold Home+9 on the remote until the lights flash, which will trigger the remote to pair again. You should then be able to continue.
Northerner
Hi @Kenno72
Tried restarting it at the mains.
If its still stuck then give ee CS a call.
DarrenDev
EE Product Expert
Nice one Darren, that worked so all is now well again. Thanks.
