EE TV Pro Box.
MJD1947
can anybody tell how/if you can adjust the subtitle size on this tv box
Lesley_W
Hi @MJD1947
Welcome to our community.
Any subtitle options will be in the 'more' button under subtitles. There may be some other helpful options on this page if needed.
Lesley
zulu17
Star Contributor
Star Contributor
I believe that EETV Box PRO doesn't  provide the option to choose the size or positioning  of its linear broadcast channels subtitling. You simply have the option of subtitles  on or off.
Some of the apps provided on the box do offer this facility which you select within the app, For example BBC iPlayer and Prime Video do. You may need to make the subtile size selection once you are watching the video.
When Youview  started the partners were committed to providing accessibility  features. Unfortunately that doesn't seem to a priority these days. The EE TV Pro remotes  have a smaller number of buttons  compared  with legacy box remotes  . Subtitle/Delete button was one remote button  that was considered unnecessary. I suspect they prioritised  frequency  of button use in their decision  making but making people  who need/ wish to use those accessibility  choices make extra button combinations doesn't  seem the right way.
The more button does exist with an onscreen option to use subtitles, audio description, and zoom  but and it is a big BUT the more button  only functions on some screens.  If using the apps on the box  you need to learn where each app has its subtitles options listed.
Could/Should  be better accessibility options and more helpful documentation.
