26-07-2024 03:33 PM
We are trying to activate the discovery plus app on our EETV box it gives us a code but does not give you the option to activate the account on the app only activate a mobile or similar item I.E tablets or pc but not TV or activate our broadband , this is not a good way to start off with new customers. We are very disappointed with this issue.
26-07-2024 03:44 PM
There are 2 stages to the process @trevor1205 :
1. Activate your discovery+ account - you should have been sent an email with instructions on how to do this.
2. Use that account to log into the discovery+ app.
Your account is currently showing that you haven't completed step 1. I believe you should be able to log into https://ee.co.uk/ and see an option to activate it, however I haven't see it for myself to know what it looks like.
27-07-2024 03:28 PM
Discovery plus not working for us either have used the email link to the ee app on iPhone iPad and via tv just won’t load or take to page has this been resolved now
28-07-2024 07:55 AM
It looks like you managed to sort this yourself around 7am this morning @Smokyjoe - is that correct?
28-07-2024 10:43 AM
Yes I did it on Google Chrome browser wouldn’t work on safari. Working ok now thanks 🤩
19-09-2024 05:43 PM
Sorry to say this but I’m having the same problem.
20-09-2024 08:56 AM
@Tomcmc have you tried the above mentioned steps yet?
20-09-2024 09:01 AM
Yes. I spent an hour last night with customer service and they couldn’t fix it. The trouble is that on the website and app my account is marked as pending which is ridiculous as I have complained about this multiple times. I have raised a level 2 complaint and I’m hoping someone will actually do something this time.
23-09-2024 08:23 PM
@Tomcmc "pending" is the correct status - it means your account is ready waiting to be activated. I suspect the issue is that your EE ID has 2 accounts on it, one of which is totally broken. What error do you see when you try to activate on https://ee.co.uk/login/ ?
06-09-2025 08:26 PM
I’m stuck too and only with Discovery+
when I go onto the “Start activation button” it takes me to “you’ll go to Discoverplus.com to create your account and activate” then it takes me to “Loading” it does this for a few sections, then the pages refreshes back to the beginning. I’ve done this numerous times. I can’t get anywhere.
