Can I swap my main ee box to another room that currently has my second box?
Sarnie66
@Sarnie66  You can put them where you want.
Midnight_Voice
@Sarnie66
What are you trying to achieve?
Do you want to swap them, or run them side by side?
What model of boxes are they?
Swapping is straightforward.
And so is running them side by side as long as they are the most recent boxes.
But what is your aim here?
(Never have a problem, conjecture a solution, and ask if the solution would work. Always state the problem, and 99 times out of a hundred, you will get a better answer).
Many thanks! All sorted.
Many thanks. Main box was in a summer room and mini in the living room. With the onset of winter needed to swap them which I have done with no issues. Thanks for your reply.
