22-09-2024 08:14 AM
If I've set a programme to record, will it still do this if the box is off or in standby mode, e.g it's not been used for a while therefore is in standby?
23-09-2024 09:54 AM - edited 23-09-2024 10:05 AM
Off at the mains, or the switch on the back if it has one, no it can’t record.
On and in standby, the box is exactly designed to wake up when a recording is due, make the recording, and then go back into standby.
Fully on, it will make the recording, and stay fully on; so you don’t need to worry about putting it back in standby to record, if it happens to be on at recording time.
22-09-2024 08:25 AM - edited 22-09-2024 08:26 AM
Hello @Penny42 ,
Welcome to the community,
If the box is off, I suspect you will not be able to record, but in standby mode, yes, I see no reason why not, you should then be able to record a program. Your TV can be off, it will still record, just in case you were wondering.
22-09-2024 08:33 AM
22-09-2024 08:34 AM
@Penny42 , you are welcome, glad I could help.
