Aerial mode. 4 recordings?
johnbhoy1979
Valued Contributor
Valued Contributor
Hi
Just signed back up to the full works.
This evening I've been recording sky sports racing.  It's my only recording this evening.
Been watching the Gloucester v Bristol rugby match on tnt.  Needed to do something so thought I would record it and watch the rest later.  When I press record it says I have too many recordings?   But I'm only recording 1!
What's going on?  Can anyone explain
Thanks in advance
johnbhoy1979
Valued Contributor
Valued Contributor
Just stopped recording the racing.
Tried to record 2 ip Channels at the same time again and it won't let me.
Can record 3 aerial channels and one ip channel.
I thought you can record 2 ip channels on aerial mode?
zulu17
Scholarly Contributor
@johnbhoy1979  The box pro is capable  of receiving  2 IP  channels so you should be able to watch one  whilst recording another or record 2 if not viewing one in either Aerial or IP mode setup.
So likely either a fault or some restriction  due to your broadband. Are you using other EETV mini  boxes  ?
Also does the problem still exist if you restart your EE TV Box Pro .. ie hold  EE  Box power button for about 8 seconds so it restarts with the EE TV powered by Youview screens. (Only do this if you are prepared to interrupt your current recording)
