Apple 4k Tv oe EE tv box
Briandl64
Since the last update on EE TV BOX, it states that I have two s et top boxes including Apple 4k Of which  I just installed, so can i use both or just one, the Apple 4k
Many Thanks
zulu17
Star Contributor
Star Contributor
hi @DarrenDev
I think that  currently regular Apple TV,s   (Ie non EE TV subscription loan boxes)  when using the EETV app do appear to be counted as a set top box albeit one with a limited range of channels ( ie TNT Sports , Discovery, Asian World).  So they are not currently being treated as one of the  upto. four on  the go EETV  devices and don’t appear in the device management section of EETV apps on other devices.
welcome back.
6 REPLIES 6
Alex_H
Hi @Briandl64,
Welcome to the EE Community
Just to clarify with you mentioning it shows two set top boxes since the update, what is your TV box setup with us? Do you have an Apple TV box fn contact rom us and an EE TV box Mini?
Or do you mean you have your box on contract from us and have  purchased an Apple TV box separately from your EE TV contract and are just looking to use your EETV subscription on that one as well?
Alex
Hi Alex_H
Sorry about not clear on the said issue, I have a EE TV set top box contracted from EE and i was given as a gift a Apple 4k TV box , so I installed the apple box and then on the screen it states that i have two set top boxes so with my contract can i use both or just one
Thank you fro your help in this matter
Brian
(Removed previously incorrect reply).
You can use the Apple TV OK, however you will keep seeing that message on your TV Box after each time you use the EE TV app on your Apple TV.  It just means your active single subscription is being moved back and forth between devices.
Other than the inconvenience of that message on your TV box, the only impact to be aware of is scheduled recordings - if you have a recording scheduled for something from a subscription channel, it'll fail if the subscription is currently associated with the Apple TV.
zulu17
Star Contributor
Star Contributor
hi @DarrenDev
welcome back.
DarrenDev
EE Product Expert
Yep - I'd already updated my response @zulu17 after checking with the team.
(thanks - great to be back).
Hi DarrenDev
Thank you very much for your reply
Brian
