16-08-2024 02:45 PM
To get the remote work a Hisense tv volume power and source?
16-08-2024 03:07 PM
Remote for what YouView box?
With the current Pro box and Box Minis, you should have your TV on and connected to the box via HDMI when setting up the remote, and it will sneak up the cable, interrogate the TV as to what it is, and then program itself to work it.
https://www.bt.com/help/tv/fix-a-problem/remote/which-remote-do-you-have/resetting-your-remote-contr...
Use the above instructions to reset and re-pair the remote if you haven’t done this.
For an earlier YouView box, the pairing code for Hisense is 1793.
