on 16-10-2024 06:50 PM
Solved! Go to Solution.
on 16-10-2024 10:08 PM
Try texting UNBAR to 150.
on 26-11-2024 09:08 PM
UNBAR
on 27-11-2024 08:09 AM
Hi @Dandanihel1
You'd need to send UNBAR as a text message from your mobile phone to the number 150.
Ali
on 19-03-2025 05:34 PM
I've tried texting 150 unbar but it's not working
on 20-03-2025 11:10 AM
Hi @Skinrug,
Welcome to the EE Community
Do you have more than one number on your account? As the text will only work on an account with one number. If you have more than one number, in order to remove a bar the account holder will need to call us on 150.
Alex
on 21-04-2025 09:44 PM
I’ve tried that and it didn’t work
on 22-04-2025 08:08 AM
Hi @adavidsonltd,
If you have been unable to remove the bar by text you will need to give us a call on 150 if you are the account holder, and one of our guides will be able to remove the bar for you.
Alex
