05-08-2026 02:37 PM
Why can I not install Sage Gen for AI Agent Protection via Cyber security on my PC?
05-08-2026 05:07 PM
Hi @Yeshe2021.
Thanks for coming to the Community.
Could you let us know where you're seeing Sage Gen AI Agent Protection and where you're trying to install it from?
What happens when you try to install this? Does the installation fail, get stuck, or not respond?
If you see an error message, please let us know what it says.
Debbie
06-08-2026 12:50 PM
It was under advanced security in my EE Cyber protection as I got an alert of having to still set this up. It asked me to protect three different GenSage areas and when I clicked on them it just led me to a GenSage link which I had to copy and paste into google. I tried to download the Gen Sage files, but they did not open once downloaded. I did a full virus and security scan afterwards and the files have now been identified as malicious and have been quarantined. I now can no longer see it under AI protection, which has disappeared, but instead there is a new tab in settings saying AI Agent Protection and when I click on this it tells me that I have no compatible agents installed on my device. Absolutely mystified by all this.
07-08-2026 05:38 PM
Hi @Yeshe2021.
I can see why this would be concerning, especially if your security software has flagged the downloaded files and quarantined them.
It's best not to try opening or reinstalling anything that's been identified as a potential threat.
Could you let us know which device you're using, and whether these prompts appeared within the EE Cyber Security app itself?
Debbie
