what is my call barring code
vpn2025
Valued Contributor
Valued Contributor
i am trying to bar all incoming calls in my phone settings and it is asking for a pin
@vpn2025  What phone do you have ?  Why not just use do not disturb if your phone has this ?
vpn2025
Valued Contributor
Valued Contributor
it is an alcatel phone, i have tried 1111 like it says on ee sim card packaging
EE's default call barring PIN was historically 1234.
Setting an unconditional "divert all calls to voicemail" would achieve the same end result.
vpn2025
Valued Contributor
Valued Contributor
how do i divert to voice mail, i will have to do that, 1234 does not work either, i dont now why a pin is even required to change settings on my own phone
