mobile locked to t-mobile
pugman227227
Valued Contributor
Valued Contributor
i have an old mobile locked to t mobile, if i bought an EE SIM card and used that in the phone would it work?
@pugman227227  You’ll need the device to be unlocked to use a EE sim.   Just to add any device from T-Mobile will be a 3G device and 3G is being switched off.
To request the device to be unlock you can USE THIS   But depending on the age of the device is might not be possible to get the unlock code as the manufacturer might not have this information as the device is that old
