13-07-2023 08:27 AM
I bought an Apple 14 Pro few days ago and change my sim to eSim. It worked well at the beginning, but yesterday my eSim turned to no signals and the phone number changed to 00000000000. I’ve tried the replace eSim, however, I couldn’t receive the “ONE PIN” thing as I don’t have signal. And now I cannot use my phone except WiFi. What should I do?
13-07-2023 10:19 AM
Hi @Kathy1229,
Have you tried rebooting the device? Why did you switch to an eSIM - do you use another physical sim in your phone?
If you have one nearby, an EE store will be able to give you an instant replacement sim or eSIM which should work immediately.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If I solved your issue, please click the solution button below! If you found my post useful, click the thumbs up button!
 If you found my post useful, click the thumbs up button!19-11-2023 07:16 PM
I have spoken to an Ee representative twice spending close to 1hr on the phone still unable to sort..now i have to wait another 24hrs to make 48hrs of trying to activate my esim
21-11-2023 10:12 AM
At midday today I'll be 60hrs waiting on eSIM. Madness isn't it?
Ever get yours sorted out?
09-12-2023 08:04 AM
I’ve got the exact same problem
09-12-2023 08:38 AM
09-12-2023 09:15 AM
09-12-2023 09:17 AM
I’ve recently bought an iPhone 14 on set up it transferred my sim to an eSIM which has never worked. I rebooted the phone and now my number is 00000000000 I can’t ring as I don’t have a landline. Nothing is working
09-12-2023 09:33 AM
Hi @asklyd,
When did you activate your replacement SIM?
Did you activate it at Activate your SIM (ee.co.uk)?
09-12-2023 09:38 AM
I transferred the sim on Thursday evening, no I didn’t activate it on ee as I wasn’t aware that I had to. I have had to completely reboot the new phone as there were loads of other issues with the set up.
