on 31-01-2025 08:54 AM
Just signed up and no where to select an eSIM currently waiting on sim delivery is this correct?
Solved! Go to Solution.
on 31-01-2025 09:15 AM
Hello @Robti1873 ,
You will have to wait until you receive your physical SIM card in order to change it to an ESIM, but only if you are on contract. Pay as you go do not have the possibility of having an ESIM.
You can do that via settings on the EE App and go down to replacement SIM card and click on change to ESim.
Hello @Robti1873 ,
