08-02-2024 06:14 PM - edited 08-02-2024 06:21 PM
I want to change my network from Lebara to EE. I have my PAC code already
Thank you
Solved! Go to Solution.
on 08-02-2024 06:37 PM
Once you've received your SIM from EE, give your PAC from your current network to EE using Fill out this quick form to transfer your number .
on 08-02-2024 06:42 PM
I will like to continue with my Lebara number
on 08-02-2024 06:51 PM
Follow the advice in the post above. It contains a link to the page where you can submit your PAC.
on 08-02-2024 07:19 PM
& so you shall if you follow my advice.
