on 31-03-2022 09:38 PM
Hello,
I've got the "wrong number showing on phone after port" problem and wondering if anyone has ever found a solution.
I have a Samsung galaxy A20e phone, brought my phone number back to Ee last Monday and all works ok ,correct number on calls and texts etc. But the phones sim card manager and about phone screen still shows the old number.
I've done a factory reset and a network reset to no avail,I've tried the sim in a Nokia phone and that also shows the old number, which suggests the problem lies with the sim card.
Phoned EE Tech but they just said to live with it.
I did think I might go to the shop to see if they could provide a replacement sim in the hope it works
Has anybody had this annoying problem and got it sorted ?
Cheers,
Del.
Solved! Go to Solution.
26-02-2023 10:16 AM - edited 26-02-2023 10:16 AM
Hi @Corky3,
Where are you seeing the incorrect allowance?
In My EE or in your phone's settings?
on 26-02-2023 10:40 AM
In my phone's sttings.
on 26-02-2023 10:43 AM
Hi @Corky3,
So your phone can report your data usage more accurately, you'll need to input your billing cycle and data allowance.
If you need any help with this, please let me know which phone you're using.
Alternatively, you can track your data usage in the My EE app.
on 08-03-2023 01:16 PM
This process works. I actually use an old Blackberry 30.
on 08-03-2023 01:23 PM
Thanks for sharing @TP27
Leanne 🙂
on 21-03-2023 11:47 AM
Hi, I'm green and don't get it, how you can edit a sim card?
on 21-03-2023 12:13 PM
I've done it, thank you 😊
on 17-04-2023 10:41 PM
Thank you 354 spent hours reading and reseting network swoping sims reseting nearly rest my phone I Phone did the trick👍💋
