Switch my existing number into EE
Rahitya_7262
How switch my number into EE
Jank0x
Skilled Contributor
Skilled Contributor
As Crhis_B stated, you send a text to 65075 with the words PAC (you may be asked to verify your identity).
Then on EE, go to Account Settings and select Switch to EE. Enter your phone number you want to keep along with the PAC code you was given and you're good to go.
If you submit the request during a working day (so before 5.30pm), the number will be transferred within one working day. If its after that time frame or on a weekend or bank holiday it'll take two days.
@Rahitya_7262   You get your PAC code from that network provider and you then give that code to EE.
From your other network provider sim you can text PAC to 65075
Jank0x
Skilled Contributor
Skilled Contributor
