Sim card not working
PeeTeady19
I got a new sim card from a nearby store, the vendor toped up as requested by me, voucher code was send to 150 for activation. An hour later, sim stopped working, no network bar, when i dail a number, it pops up 'Number not registered'. Anyone got an idea what could be the problem.
Thank you.
Hi @Christopher_G
Yes I did that severally, also swapped fro one sim port to the other. It picked up late at night eventually.
Thank you all for all options and ideas.
9 REPLIES 9
Northerner
Hi @PeeTeady19
Are you in the UK.
It sounds like the number is dead or your phone is not unlocked/blacklisted
Hi @Northerner
I live in the UK,
My phone is a doubled sim Android and my other line is working perfectly, I really do not think its blacklisted.
Thank you.
Northerner
Hi @PeeTeady19
I asked if you are currently in the UK.
Have you set your dual SIM up correctly.  Which android phone do you own.
Hi @Northerner,
I am currently in the UK.
My dual sim is correctly set up, I have been using 2 sims on the phone (Samsung A03) actually removed my second line, and replaced it with the new EE sim I bought. It worked initially, but stopped working after a while. Like 1-2 hours.
Thank you.
Christopher_G
Have you tried restarting the phone, or manually searching for a network, @PeeTeady19?
Hi @Christopher_G
Katie_J
Thanks for letting us know @PeeTeady19.
Katie 🙂
Qudsiamahmood
My sim not working on iPhone 7
Christopher_G
Hi @Qudsiamahmood
Welcome to the community.
Have you tried restarting your device? Are you getting any error messages?
