on
13-04-2023
11:56 AM
- last edited on
13-04-2023
01:02 PM
DanielPA
[Mod edit: Please do not post phone numbers on the public board. Thanks!]
Solved! Go to Solution.
on 13-04-2023 01:09 PM
Hi @Loddyjohn08.
The quickest way to get your PUK code to unlock your SIM is to log in to your My EE account and follow these steps:
scroll down to Unblock SIM (PUK code)
select Show PUK code
Katie 🙂
Hi @Loddyjohn08.
Katie 🙂
on 13-06-2023 03:19 AM
Need puk code
on 13-06-2023 07:38 AM
Good morning @Khatib123.
You can get your PUK code by following these steps:
Thanks,
Katie
on 02-09-2023 08:57 AM
Hi, there is no option to do this
on 02-09-2023 10:49 AM
Hi @LEDTek
Are you looking to get a PUK code? Our Mobile Care team will be able to help you with that.
on 27-03-2024 09:44 PM
The EE app doesn't show the information that you're on about
on 27-03-2024 11:00 PM
As @Katie_J has mentioned correctly, you need to log into the required EE account on a computer and then it will show it under 'Phones & Devices', you will not get it on the EE app.
EE - Computer
PUK Code On Computer
EE - App
PUK Code On Phone
on 27-03-2024 11:01 PM
Log into your account on a computer, not through a mobile, then do as @Katie_J has mentioned and you'll be able to find the required PUK code.
