Replacement sim
Greg365
Hi
I returned from abroad and discovered the sim has gone. So I ordered a new one. It arrived, I put it in as instructed bit it won't connect to the network.
broadbandcat
Hi, I’ve had similar problem. Took sim into ee store and they replaced and activated it . Worked fine . Good luck
7 REPLIES 7
Greg365
The sim arrived (the last one was removed and lost) and I put it in but nothing.
@Greg365 : Are you on contract or PAYG?
How long were you away from UK? Did you not use your SIM during that time?
Hi. I was away 3 days in a non EU country. Faroe Isles. I ordered the
replacement. Its in and detected just not connected.
Christopher_G
Hi @Greg365
Welcome to the community.
Could you try restarting your phone this morning please? Has the SIM activated?
No joy. Thanks though.
broadbandcat
Oh. Sounds like I'll be heading there too. Will combine with overdue upgrade
Cheers
