21-11-2024 10:48 AM
Hi.
I mistakenly deleted my eSim, thinking I could go back to the old SIM card, which I now realise is not possible.
How can I get a QR so that I can set up the eSIM again?
Fenner
21-11-2024 12:37 PM
Hi there @fennerpearson
Welcome to the community 🙂
If the eSIM has been deleted, you would need a replacement eSIM or physical SIM sent to you.
To do this, you can get in touch with us, or visit an EE Store with photo ID and the team will get this replaced for you.
Hope you get sorted 🙂
21-11-2024 12:37 PM
19-02-2025 04:01 PM
How can I get an esim replacement by the web?
19-02-2025 06:09 PM
Hi @jevives
Welcome to the community.
It depends whether you're replacing a physical SIM with an eSIM or going from eSIM to eSIM. This Set up and use an eSIM article explains how to do it in both scenarios.
