on 01-08-2022 02:10 PM
Hi, I'm also having the same issue. I have my pac code from BT, but when I enter it into the online form, a red box comes up saying:
"Please make sure you enter the right code. Your PAC will look like ABC123456. Your STAC will look like 123456ABC."
I have checked and checked again that I am entering the correct digits / format.
Very frustrating, can you help?
on 01-08-2022 02:53 PM
Hi there @slyddon
Thanks for coming here 🙂
If you give us a call on 150, the team will make sure the number transfer is set up for you.
Thanks.
Leanne 🙂
