RCS texting number incorrect after port
armstra101
I have recently moved back to EE and ported my number, which didn't go smoothly but is finally sorted. I can make and receive calls and SMS on my ported number.
The problem is RCS messaging. When I send one they appear to come from a different number, presumably the one that EE had on the SIM card.
I've checked the number in RCS settings and it's using the number provided to me. If I turn RCS off and back on it attempts to connect with the ported (correct) number but after a second it switches to the incorrect number and connects.
How can I fix this? I have a Galaxy S22.
Cheers
Andrew
39 REPLIES 39
Katie_J
Thanks for getting back to me @ConfusedMatt.
Does the correct number show in your phone settings under Phone Number?
Katie
ConfusedMatt
It's says unknown for that.
I've tried putting mine in but it disappears when I re enter the menu.
Below that, the EE issued number is in a box I can't edit.
Katie_J
Hi @ConfusedMatt.
Thanks so much for checking.
Have you been able to speak with our technical care team on 150?
Do you have a physical SIM or an eSIM?
Katie
Physical SIM. I'll review my options and consider terminating my contract.  Thanks
Katie_J
I'm sorry to hear you are thinking of leaving @ConfusedMatt.
Our technical care team will be able to look into this further and get this resolved for you.
Katie
I've spent an hour trawling through threads on here. It's a known issue.
I wasn't informed of it before my porting of my number.
I'm now struggling to log into my HMRC childcare account.
I'm not in the right frame of mind to speak to a technical support team.
I'm absolutely devastated that the inconvenience caused by EE is having such a huge impact.
The website sign posted me here and now I'm being told to ring someone else.
This isn't good enough.
Katie_J
I understand coming to the EE Community can be alternative way to get in touch without calling @ConfusedMatt.
Here on the EE Community we have no account access so we are unable to complete a full diagnostics for you.
Do you live near a local EE Store? I would love to help get this resolved for you as soon as possible so you can gain access to your HMRC accounts.
Katie
I don't find that response or this quality of service at all appropriate.
Thank you.
Katie_J
Hi @ConfusedMatt.
When you have a moment please check your community inbox.
Katie
Calling 150 means you get an automated message which checks your home broadband, says there's no problems then hangs up. Not possible to speak to a human.
