Puk code
Wholenut
The how to unlock or find your PUK code is outdated in the community forum. To find your PUK code, just to to account settings and scroll down and you will see a PUK code for your device. Make sure the number shown in the box at the top of the page is the number for the device you are trying to find the PUK code for.
You'll find the PUK, to unblock your SIM after too many incorrect PIN attempts, in your online MyEE under Menu > Account Settings > Unlock your SIM.
16 REPLIES 16
Alex_M
Star Contributor
Star Contributor
Where are you seeing this? The instructions seem clear and different to what you've posted on the EE website.
https://ee.co.uk/help/my-account/pay-as-you-go/how-to-unblock-your-phone-with-a-puk-code2
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
basiek2010
Hi .When I'm going to MENU I don't have a option account setting. I only have Home ,Shop ,help and Business.Please help.I contact ee but they can't help.
James_B
EE Community Manager
Hi @basiek2010,
Tap here to view your PUK code.
Hope this helps.
Hi James.
Thank you so much for your help.My phone is working now.Hurray.
James_B
No problem @basiek2010 🙂
This worked finally.
I had the same problems as above as it's not displayed as described in the EE help.
https://ee.co.uk/plans-subscriptions/mobile/settings-permissions
That's the page you want to go to
Your puk will be displayed there about half way down.
There is no option under Menu to get to Account settings!
Not helpful at all .  Your solution doesn't work.
