ā30-11-2024 08:25 AM
I put my new SIM in my phone 28th Nov and use the text service to set it up - I had a test to say it would all be done by 6pm on 29th. However it is now 30th and has not happened, so currently i am not connected to any network on my phone,
As EE only commumicate by text to on a call I can't even tell anyone of this situation to get anyone to check it for me.
Catch 22 it seems
ā30-11-2024 10:23 AM
Did you receive any further text to advise of port-in complete? In any case, you shouldn't have lost network service - the worst case would be still using your temp number and a delay to the port-in.
If you perform a manual network search on your phone, does EE show and can you manually select? Or try toggling flight mode.
If all else fails, you can contact EE-CS on 07953 966150 from any working phone, or +44 800 9566000 from a web-calling app such as Skype. They have access to your individual account and can advise further.
ā30-11-2024 09:00 AM
Hi Sue
I know from my experience they donāt do porting at w/eās so if it hasnāt been done yet it might be Monday.
Meanwhile, calls over WiFi should work on your WA contacts or other numbers via Skype.
