05-02-2025 11:26 PM
Evening all,
I have been advised to forward my ports in relation to a Eufy Homebase 2 to establish a better connection with the Eufy doorbell.
I was advised to change to the below
TCP port 80, 443 and UDP port 65535.
Can anyone advise how I change to this? I have gone into admin, firewall, create rule but then it says internal and external with a start and end for both?
Thank you for any advice.
05-02-2025 11:43 PM - edited 05-02-2025 11:47 PM
For single ports you usually put the External = the Internal. So you would have 3 rules:
I v. much doubt you need 80 & 443. They are into the router itself. A doorbell shouldn't need any incoming ports open. Who told you that?
On which router?
12-07-2025 08:42 AM
Hi, did you manage to fix this as I’m having issues with connecting the doorbell to my wifi? Tried the porting but it didn’t work
