on
03-08-2025
07:39 PM
- last edited on
03-08-2025
08:30 PM
MikeT
Hai
I need to port from lyca to EE
What is mean PAC, & How to get PAC code?
Can you please help me with this
Solved! Go to Solution.
on 03-08-2025 07:53 PM
@Harijay72 : PAC = Port Authorisation Code, used for porting mobile nos between networks.
As you want to keep your number, text PAC to 65075 from your Lyca no.. It will respond with your PAC & how much you will have to pay in Early Termination Fees if you are still within your min term. Give the PAC to EE while you are ordering your EE SIM. This will have the effect of cancelling your Lyca contract
04-08-2025 08:26 AM - edited 04-08-2025 08:38 AM
HI @Harijay72
Just to add what @XRaySpeX mentioned- once you have the PAC code from Lyca, the easiest way to give your PAC code to EE is just text PORT to 150 from your new EE sim. This will take you through 2 steps to submit your PAC Code and transfer your number.
You can find more information at Transfer your number to EE
Hope this helps!
Ali
