06-12-2025 04:49 PM
Hello,
I have activated my SIM card and completed the identity verification process, but I am not receiving any SMS messages or phone calls. Because of this, I am unable to receive the verification code needed to create a Google account.
Please check and resolve the issue with not receiving messages and calls.
Thank you.
07-12-2025 11:47 AM - last edited on 07-12-2025 11:51 AM by Katie_B
my number is ********
Mod edit: [please dont post personal information on the community].
07-12-2025 11:49 AM - edited 07-12-2025 11:51 AM
@Raha1944 , did you activate your SIM card in the UK and make a chargeable call or text before going abroad? If you did not, then you cannot use the SIM card until you return to the UK as it first needs activating in the UK.
Did you receive the welcome message from EE? If not, then that proves that the SIM card has not been activated, as EE is a UK network, it would first need activating in the UK, and once done, you would have received the welcome message, where you can pay for credit to use it abroad.
Plese also remove your number as per forum rules, this is a public forum and you could get spammed.
07-12-2025 11:53 AM
Welcome to Turkey. Calls cost £1.80/min to make and £1.80/min to receive and texts 60p each. Picture messages cost 48p.
Using data is worry free, click add-on.ee.co.uk for FREE to get more information or choose a set amount of data and if it runs out we'll check if you want more, so you always know what you're spending.
Your current balance is £0.00
Call +447953966250 for Customer Services & 112 in case of emergency. Have a good trip!
. IWelcome to Turkey. Calls cost £1.80/min to make and £1.80/min to receive and texts 60p each. Picture messages cost 48p.
07-12-2025 11:56 AM
Hi @Raha1944
As @Schockwave asks you need to activate EE Sims in the UK on the EE network. If you haven't done this then the SIM will not work.
07-12-2025 11:57 AM
I just paid £5. What should I do now? I need to use my SIM card.
07-12-2025 11:58 AM - edited 07-12-2025 12:01 PM
@Raha1944 , if you have received the welcome message, then click on it to add data, simple, use the message to do so, that is the only way to add data for you to use, by using the message and following it.
I would suggest putting more credit and also try doing a manual search first to see if you can get one of the networks to work, this is always recommended, also try putting your phone into airplane mode and back again, reboot your phone, these are the ways to see if it all works.
