How to change my number to EE and promotion for student?
fych
Hi, I currently use giffgaff, I would like to switch to join EE.
How can I do it? And how much does it cost?
I looking for monthly sim promotion.
Christopher_G
Hi @fych
Are you looking for a pay monthly contract? If so, you can browse them on our online shop and add your student discount code at the checkout.
Once your account is set up, you'll be able to port your number over from your previous network after they give you a PAC code.
Thank you for your answer.
Which one should I do first between ordering a EE sim or getting a PAC code?
Christopher_G
Personally, I'd get a PAC code from them first, @fych. I wouldn't like to order a new contract without knowing for sure that I had one.
