BT Phone
Fob4
Been offered an iPhone buts it’s locked to Bt. As BT and EE are partners will my EE sin work in the BT phone.
Alex_M
Star Contributor
Star Contributor
Hi @Fob4,
When was the phone purchased from BT? It it was after December 2021 then it will be unlocked anyway.
If it is locked, then you will need to call 0800 800 150 and a BT advisor will do this free of charge.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
Alex_M
Star Contributor
Star Contributor
Hi @Fob4,
Thanks,
Alex
manc_mikeh
EE Knowledge Specialist
Please note 0800 800 250 is OOD, best number is 0330 1234 150.
