Antenna
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-08-2024 12:53 AM
Does an Estonian SIM card have roaming in Iran? My SIM card does not have an antenna in Iran. Please help me on this matter. Thank you
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-08-2024 02:29 AM
EE has nowt to do with Estonian SIMs. You'll need to check that with your Estonian provider.
Re: Your EE SIM ...
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-08-2024 02:29 AM
Re: Your EE SIM ...
