07-02-2026 01:29 PM
I have an EE sim card in my 4g antenna outside - it has stopped working, I have unlimited data but when I look on the useage it says "stacked" what does that mean? also it says I have 0 date left
07-02-2026 02:58 PM
Is it PAYG and a data only SIM. There is no such tariff as unlimited as this is normally 600GB if you read your terms and conditions.
Stacked means there are two active data bundles I believe.
07-02-2026 03:01 PM
Hi there Northerner
No, its pay monthly and I do not think it is a data only - I have not used any data on it though and it is still saying I have 0 data left. I only have one data bundle.
07-02-2026 03:08 PM
Have you recently upgraded?
Tried restarting the device.
07-02-2026 03:10 PM
No but its out of contract, has been for a while - yep, tried that just won't work - I am guessing I will need to get someone to look at it as I don't fancy jumping on the roof of my house to find out 🙂 The antenna has maybe moved - I just thought I would find out if it was the sim first but trying to get customer advisor is a bit hard.
07-02-2026 03:43 PM
What does texting AL to 150 from your no. fully report verbatim (it is free)?
