30-04-2025
08:27 AM
- last edited on
30-04-2025
09:46 AM
kh-laura
I use wifi when I am in my house in Portugal to use internet, no problem browsing in the house or by using mobile data out the house. I want to use my IPhone to make UK calls in and out of the house, the phone does everything else it should do apart from be able to make calls. It worked perfectly for several months until yesterday when I can't make any calls. My wife has the same issue.
I can still use WhatsApp for calls but normal calls will not connect.
We both have roaming so no issues with that.
I hope this helps the experts.
Ken
30-04-2025 09:04 AM
Use of WhatsApp is the same as any other internet-app in proving an internet connection.
Can you confirm the following work when only connected via a mobile network and not WiFi... sending & receiving texts? Receiving calls?
Is there any difference in symptoms between calling in-country, and calling internationally (including to the UK)?
Are you & your wife connected to the same local network? And are the symptoms the same if you manually select a different local network?
30-04-2025 09:45 AM
Answers next to questions, thank you for trying to help
Use of WhatsApp is the same as any other internet-app in proving an internet connection. - OK I note that, thank you.
Can you confirm the following work when only connected via a mobile network and not WiFi... sending & receiving texts? Receiving calls? I cannot make calls to UK or to a Portuguese number, regardless of whether or not I am connected to Wifi
Is there any difference in symptoms between calling in-country, and calling internationally (including to the UK)? - Can't make calls anywhere
Are you & your wife connected to the same local network? And are the symptoms the same if you manually select a different local network? - I can't see anything on my Iphone that indicates I can select a different local network. I know I could do this with phones I had in the past but nothing shows on my current Iphone, same with my wife's phone.
As I said previously, everything worked perfectly for many months until yesterday.
