29-04-2025
06:00 PM
- last edited on
30-04-2025
09:33 AM
kh-laura
The same thing happens to my wife. We are in Portugal at the moment and for the last couple of calls from our son in Switzerland have gone straight to her voicemail so he contacted her on WhatsApp. A call from her sister in the UK said the number is unavailable. Our daughter calls her everyday from the UK and gets through every time with no problem. They all have their names & numbers saved in her phone. The handset is fully up-to-date has plenty of memory and they are not blocked as here sister got through the following day! This has also happened when we are in the UK with other people both listed in her address book and not listed i.e. number unknown.
30-04-2025 08:27 AM
Hi @Pontiff1
Could you search in the settings to make sure that 'Do Not Disturb' is not activated please? If it isn't, it may be worth manually searching for another available Portuguese network to see if the same thing happens.
30-04-2025 09:32 AM
30-04-2025 02:02 PM
Thanks, @Pontiff1
It may be worth having a chat with our Customer Support team from another phone, so that they can check everything from our side for you.
Hopefully they can help get it working for you again.
