Roaming not working in China
Dolly68mike
Hi there, i have paid for roaming but phone isnt working. Im in China on business and need signal and texts
Ali_A
Hi @Dolly68mike
Did you activate the Roaming access before leaving for China?
You can usually do this by texting ROAMING to 150 while in UK.
If both Access and bundle are active, the next steps would be to try a manual network search to see if you can connect to one of the networks.
Ali
