30-04-2025 03:46 PM - edited 30-04-2025 03:47 PM
I spoke to CS about not being able to make outgoing calls to UK numbers while roaming in EU and was told it's an ongoing issue they are aware of it and working on a fix. After reading some posts on here, it appears that it's been going on for a while. Why haven't EE put out a notice of it somewhere, or texted everyone affected, with an ETA of a fix? That would have saved a lot of headache. Personally, I'm really disappointed, it's the first time I've tried EE's roaming and I'm only able to receive calls, texts, thankfully data works as well so there's WhatsApp, but it's unacceptable to have to make numerous calls to CS to find out about it, and no estimate of a fix.
30-04-2025 06:02 PM
Neither Orange nor EE have ever had a customer-facing "known issues" board, and it could easily create as many problems as potentially being solved.
Users who see a "known issue" and assume their problems are caused by that, are less likely to seek individual help and thus unrelated issues go unresolved - I have seen this happen in both a professional & personal capacity. "Me too" posts on this very forum are also another example - it's basic human nature to see similar issues described, and be relieved there's no need to pursue yours.
Doing things the way they're done (which is commonplace across the mobile industry), does rely on a solid & reliable CS-process, though.
Text notifications are an interesting one, that relies on having agreed criteria for selecting the recipients. Do you base this on users who have connected to foreign networks in the past x days? You potentially upset or confuse those who have now returned home or travelled elsewhere. Similar text-based comms have been used before - but you need to make the criteria viable & workable.
30-04-2025 06:30 PM - edited 30-04-2025 06:31 PM
Yes I see your reasoning. But still I don't see why it can't be mentioned, for example, in the 'welcome' text upon landing, or on sending the text to set up roaming, or somewhere in the app. I'd still prefer to know even if there could only be a potential issue. Much like, say, knowing about roadworks ahead of travel or other potential disruptions.
01-05-2025 09:00 AM - edited 01-05-2025 09:00 AM
Yes. I'm in Poland. Still can't make outgoing calls.
01-05-2025 01:52 PM
@pwalk wrote:Yes. I'm in Poland. Still can't make outgoing calls.
I'm puzzled why my reply was moved here from the other thread? I was replying to a question if anyone is still having issues.
08-05-2025 11:11 AM
I am in Germany and also experiencing this problem. Does EE offer a refund for failing to provide a service that is in the plan?
08-05-2025 08:09 PM
They seem to have fixed it for me on Tuesday. I got a text from EE saying we've updated your network settings, then a welcome roaming text yesterday, and I can make calls!🕺 Re. refunds, I don't think they offer them on add-ons.
09-05-2025 08:07 AM
Morning @Paulw46
Can you send and receive texts? Did you receive a welcome message from EE when you landed?
Thanks.
09-05-2025 08:34 AM
I had a welcome text when I arrived in the EU, saying "thanks to your roaming pass you can use your UK plan allowances".
However, I cannot phone or text the UK, but I can receive texts and calls. I am in touch with technical support who say it is an ongoing problem and I am waiting an update. Meanwhile, I have to use my wife's vodaphone which works OK.
09-05-2025 10:38 AM
Thanks for the quick reply @Paulw46
If this has been reported to our tech guides they will be getting this looked into for you. Once they contact you back with an update you can discuss any potential refunds for any add-ons you have purchased.
