Issues with Roaming Coverage
MSow
I know this issue was reported a while ago, but after travelling to several European countries recently, I’ve consistently struggled to get any mobile coverage at all — not just data. In some cases, I couldn’t connect to any local network.
I also haven’t seen any recent updates or information from EE about this, which is a bit concerning.
It makes me wonder whether some EU providers are deliberately restricting UK SIMs from connecting to their networks.
Leanne_T
Morning @MSow
Are you roaming at the moment or in the UK? Have you been able to use the phone for calls, texts and data at all in the EU?
When you had no network available, did you manually try searching for a network to see if any available networks showed?
Speak soon 🙂
@MSow  Did you restart the device in each location you went too ?
