Roaming in EU
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
22-04-2025 12:12 PM
I have paid for 7 days roaming in Finland, EE says all ok but can’t access it.
how can I get EE to sort this out?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
22-04-2025 12:26 PM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
22-04-2025 05:17 PM
