Re: Remove Spend Cap
Alin29
Hello
can you help me to make calls as I’m in Romania and I can’t call even uk numbers or numbers from Romania
Katie_J
Hi @Alin29.
Thanks for coming here.
When you arrived in Romania did you receive a welcome text from EE?
Did you activate roaming before leaving the UK?
Are you aware of a spend cap on your account?
Katie
@Alin29 : Did you receive a Welcome text upon arrival?
