text message roaming confusion
sjn19
I'm now based in Canada, but have kept my EE PayG number active for return trips to the UK.  When those trips were going to be so far apart that I risked 'hibernation',  I'd simply activate my EE SIM, turn off my Canadian SIM & WiFi, and send a chargeable SMS to my Canadian number.
In the past, that worked perfectly.  But lately I've been unable to send SMS texts from my EE number, in Canada.  Attempting just produces a 'Not Delivered' error (and they are clearly trying to go out as SMS - not iMessage)
I still get the usual EE 'Welcome to Canada' text, showing PAYG rates for calls and texts.  And voice calling works, so I can still generate the necessary 'chargeable' activity to keep the account active.
But I'd really like to understand what's now preventing me from sending regular SMS texts in this context - especially since it always worked fine in the past.    Thanks!
17 REPLIES 17
Does the same happen when you send a text to yourself?
sjn19
Yes, I am trying to send the SMS to my Canadian number, while connected via my EE one (and Canadian eSIM turned off).
The 'not delivered' error message comes via EE, and the SMS also never arrives at my Canadian number.
No, I'm asking you to send a text from your UK no. to your UK no.
sjn19
Ah - sorry I misunderstood!
I'm afraid I can't try that right now, but I should be able to do so later this evening.  Will post an update then.
sjn19
Got a chance to try earlier than expected:
- only EE SIM active,  Wifi-off, testing SMS (not iMessage) to UK number -  and the same result: unable to send.
Fortunately, I can make a 'chargeable' phone call to keep the account 'active' - though it seems odd pay-per-use isn't working for SMS, but works fine for voice
When did you last top-up?
sjn19
I either top up, or send a chargeable 'maintenance' text, every 5-6 months from my last activity.  But I've accumulated quite a bit of credit, so lately I'm trying to mostly use the 'chargeable activity' method.
But when last did you top-up? I'm only interested in when you did this action, not how you use it.
You could try topping up now & see if these texts from your UK no. now work.
sjn19
My last top-up was exactly 1 year ago - Feb 18, 2025.   After that, I had an extended visit to the UK in March, and then some chargeable text activity in Canada about 5 months ago.   And there's still lots of credit left in my account.
My understanding has always been that either topping up or doing something chargeable at least every 6 months would both have the same effect on keeping the account active.  That's the way it seems to have been, for a number of years.
If that was wrong - i.e. if it's only top-ups that 'reset' the clock, rather than also chargeable activities - then the 'one year top-up anniversary' might, on the surface, appear to explain the problem.
And, in the absence of any other solution, I suppose I could top up a small additional amount, and see if it makes a difference.  But ...I had no problem making a chargeable phone call today  - and verified that my balance was reduced accordingly.  In other words, only sending SMS messages has failed to work..
