20-02-2026 08:48 AM
20-02-2026 09:18 AM
Data roaming means using mobile data whilst roaming, it has no impact on text or voice services.
Can you receive other text messages? Can you receive other calls? Are both Iranian networks affected, or just one specific one?
Have you been able to receive calls or texts, the welcome message aside, whilst in Iran on this trip? Can you be more specific about your statement "this worked before but stopped recently" - is "before" on this trip or a previous one? When exactly is "recently"?
20-02-2026 09:22 AM
You're on PAYG. Where did you get your SIM? Had you used that PAYG SIM for making calls or texts in UK before going abroad? To be used abroad EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
20-02-2026 12:14 PM
Hi @Mary8863
It might be blocked by the state as only a few weeks back they disabled all mobile networks, foreign network access might be blocked.
