on 23-09-2024 10:40 AM
23-09-2024 11:03 AM - edited 23-09-2024 11:05 AM
Hi @kirkhamj939
Welcome to the EE Community
Are you on Pay monthly or Pay as you go?
You can check the costs and bundles available for Pay Monthly at EE Roaming
By default you will normally be on the daily roaming plan, which is £2.47 a day to use your calls/SMS/data plan allowance like you would at home.
You can find out more at EE Roaming in the EU
If you're away for 10 days or more it may be worth taking a roaming pass instead, which is £25 and lasts 30 days.
You can find details how to add this at EE Roam Abroad Pass page.
For Pay as you go you can pay £2.50 a day, or £10 for seven days, to use your UK allowance while abroad in EU. You can only purchase these bundles once you arrive at your destination. You will receive an SMS which contains instructions on how to add these products.
If you don't have a monthly PayG subscription in place, standard rate without the daily or weekly pack will be charged 70p per minute and 30p per text and will need to purchase a separate add-on to use data.
For details of the roaming packages for Pay as you go just go to Pay As You Go charges for roaming in the EU
Ali
Hi @kirkhamj939
Ali
