02-06-2025 06:14 PM
I landed in spain 2 days ago, I have a roaming pass on my plan which should mean i can have data however since landing i have no signal, have read through this page tried everything, rang ee and said everything should work however nothing is working. i have tried everything on settings however it won’t pick up signal at all. any help?
02-06-2025 06:17 PM - edited 02-06-2025 06:29 PM
Have you used your phone abroad previously, did you receive a welcome text message on first arrival abroad? These are good evidence of roaming being enabled if so. In these cases, manually cycling through all available local networks often resolves issues - toggling flight mode can have the same effect. You mention trying "everything" but being specific would be more useful.
You did the right thing in contacting EE-CS from another phone to report this. Presumably they enabled roaming remotely, and advised you of this. Did you try a manual network search whilst on the phone to the agent? Were you able to connect to another local network?
And if not... what did the agent advise when you told them of this?
