on 05-12-2024 10:06 PM
Hey, hope someone can help. I have been away in Germany and while I was there my phone wanted to update its software. Once it had updated, I realised I couldn't make any telephone calls out, couldn't send any text messages or even receive calls on it. I thought it was a problem with Apple so I've been onto them and they've done all they could. Apparently it's an EE issue. Can anyone help please? Thanks
on 05-12-2024 11:04 PM
Did your phone work abroad before this software update? Or did it never work abroad in the first place?
on 06-12-2024 10:53 AM
06-12-2024 11:57 AM - edited 06-12-2024 11:58 AM
If your SIM has worked abroad, roaming is evidently active. If the only change between "working" & "non-working" is a device software update, then there's the cause of the problem.
Are you using an eSIM or physical SIM?
Does the phone show a connection to any local networks? What happens when you try making a call or sending a text message?
