03-11-2025 10:46 PM
I tried trying text roaming as requested to 150.
They said "Just grab a Pass" Unfortunately there is absolutely no information as to how to actually go about "grabbing a pass"
It says it's £25.00 for seven days.. Great - let's go then! - but how?? I've tried the website and there is zero information there either.
I'm a bit concerned because last time I went abroad customer service said I was "all set" only to find that I couldn't use the phone at all when I got to Canada .
Does anyone have a link to a place where I can actually sort this out - or some trick I can use to actually talk to a real person at EE?
03-11-2025 10:59 PM
Are you still in UK or have you gone abroad? If so, where?
03-11-2025 11:03 PM
You mentioned texting ROAMING to 150, but assuming you did this in the UK, what did you receive by response?
I presume that "they said "Just grab a Pass" was the comment made by a CS agent when you spoke to them? Or was that the text reply you received? That would be a bit unusual if so.
Other advice does depend on answers to XRaySpeX questions above.
