Why can’t I use my data in Austria
Ash1351
My unlimited free data and talk is not working in Austria
Ash1351
can I get some help please
@Ash1351 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
